'91 2wd truck automatic transmission woes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2003, 08:09 AM   #1 (permalink)
View bachlauter's Photo Gallery
HI all!
I have a transmission questoin or two for you...
Just got this truck...changed out all the fluids....the transmission fluid was WAY OVER FILLED.....is that a trick to "quick fix" a problem??
I put in the proper amount of fluid and strange things have been happening..
when I put it in "D" and hit the gas, there is a second or two of hesitiation before it will go.
Today, I got in it cold and put it in "D" and tried to drive it up my driveway and it would NOT go for like 5 seconds...it took me three tries to get it to MOVE!!!
Does this typically mean and ENTIRE new tranny OR could there be internal parts worn, that could be replaced??
HELP!!!!!!!!!!!!! I'm freaking out!!!
~Christy
bachlauter is offline
Old 10-16-2003, 08:58 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Are you sure you were filling through the proper hole? Most transmissions have a drain hole and a fill hole (which is the higher of the two)....
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 10-17-2003, 11:02 AM   #3 (permalink)
robinhood150's Avatar
View robinhood150's Photo Gallery
The fill hole in this case should be the place where the dipstick goes in.
I would check the level of the fluid again. Did you check it with the transmission hot, the engine running and did you cycle through all the gears first?
BTW, Christy, you have a PM.
'93 4Runner V6 Auto 4x4
Robinhood's Lair.
robinhood150 is offline
Old 10-18-2003, 12:19 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
Ahh.....I read the title of the thread....but it didnt register that it was an auto.
JeremyH is offline
