also noted in the book is 40 to 60 ohms for 1984 models (60 to 80 for 85-88) the resistance between terminals 3 and 4 should be infinite. on 89 and later there should be continuity between terminals 3 and 4 but none with 2-4, and 3-4, this one is on the driver side kick panel. and this one is called the main relay
now for the pasenger side relay that one is called the circuit opening relay
and for our v6 buddy the same passenger side relay but you have a little more work
check to make sure it is working as the picture shows then you have to apply batter voltage across terminals SAT and E and verify that there is continuity between terminals B and Fp. apply battery voltage across terminals B and Fp and verify that there is continuity between terminals B and Fp.
all pictures and most information on how to do this was taking from the hanes repair manual #92075
