no start when cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-22-2003, 01:02 PM   #1 (permalink)
View llervero's Photo Gallery
Angry no start when cold
I have 22re EFI and in the mornings or whenever the engine has cool down the truck would not start it will take at least 15 times to start some times even more. Can anybody help me here. Spark plugs, wires, rotor and cap are a few months old. Clean the throttle body and change the air filter. After the truck starts and warms up it runs fine.
llervero is offline
Old 11-24-2003, 04:00 PM   #2 (permalink)
crackakilla
ChuckD's Avatar
View ChuckD's Photo Gallery
Cold start injector or time switch, start with tose two items.
ChuckD is offline
Old 11-25-2003, 03:07 PM   #3 (permalink)
Which one is the cold start injector and where is the time switch
llervero is offline
Old 11-25-2003, 10:03 PM   #4 (permalink)
View skperl's Photo Gallery
Experiencing similar problems here too. Have 90 3.0 efi 4x4 auto pickup. Cold starts are a pain usually have to crank 2-3 times to start. Thought it was cold start injector, tested with ohm meter per repair manual, tested fine. Took it to repair shop they blamed it on the time switch which I believe is screwed into thermostat housing or close by. Haven't looked yet to see exact location, has a plug on it like injectors do. Cold start injector is on passenger side of engine, if your engine is efi it is in aluminum housing right in the middle on the passenger side. Problem still persist with cold starts being a pain, tech said my fuel pump is working spuratically, he did put a pressure gauge on the system and said it is holding pressure. I am also experiencing a stall at 3500rpm, merging on interstate accelerating tach goes to 3500rpm then drops to 3200-3300rpm then pull right back up and acceleratates fine after that. Any suggestions before I go tearing into the gas tank?
skperl is offline
Old 11-26-2003, 01:32 PM   #5 (permalink)
I'm going to try to start troubleshooting this suggestions this weekeend. Thanks guys, I'll get back to you with the results.
llervero is offline
