My 89 Toyota Pickup Died - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2003, 08:51 AM   #1 (permalink)
View Joe0606's Photo Gallery
I was driving my pickup,when it just seemed to miss very badly all of a sudden then it stalled. I was able to get it started again and get it to my destination by holding the gas half way down the entire time, when I got to my destination it just died. I changed the plugs and wires, distriuter cap was good, I also tore it down to the timing belt to make sure that it hadn't slipped. I had been getting a check engine light for the throttle position sensor, so I changed that also. I was getting spark and I had changed the coil 9 months ago. I also changed the fuel filter. The open circuit relay inside the cab was also changed. Now it just won't run or barly runs at half throttle. I also have a spare computer and swapped that out to see if this was the cause but to no avail. Any help would be appreciated.
Joe Pa
Joe0606 is offline
Old 12-01-2003, 12:39 PM   #2 (permalink)
View monty's Photo Gallery
Humm, is it carb or injected?
either way, id look at the fuel suply.
monty is offline
Old 12-01-2003, 03:23 PM   #3 (permalink)
yes, it's fuel injected, I changed the fuel filter and it smelled like it was loading up while I cranked it.
Joe0606 is offline
Old 12-01-2003, 11:56 PM   #4 (permalink)
View OEMonkey's Photo Gallery
did you adjust the TP sensor when you replaced it?
OEMonkey is offline
Old 12-02-2003, 06:07 AM   #5 (permalink)
No I did not adjust it, bu there doesn't seem to be room for adjustment unless it swivels on the screws. Still, if you did not adjust it will it still not start with a new t.p.s. ?
Thanks for the input, it is appreciated.
Joe0606 is offline
Old 12-06-2003, 09:04 AM   #6 (permalink)
I cracked open my fuel line and had someone turn the key on, and I got no fuel. However, when I turned the key to start the fuel pump started pumping. Is it possible my ignition switch is bad?
Joe0606 is offline
Old 12-13-2003, 03:07 AM   #7 (permalink)
View greasemonkee87's Photo Gallery
JOE, You might wanna test the compression to see how good the cylinders and internals are. You could have low compression and that could be the reason why it runs crappy if at all.
greasemonkee87 is offline
Old 12-14-2003, 12:12 PM   #8 (permalink)
I will check compression, but the fuel pump does not initiate when the key is put to the on position, it does however start pumping fuel when the key is twisted to the start position but the truck still does not start. This is why I think the ignition may be bad. Any thoughts?
Joe0606 is offline
Old 12-14-2003, 03:50 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
Look at the lil condensor in the distributor, these are a common problem on toyotas at my shop. What kind of truck engine do you have with a timing belt?
雄のハヤブサ
Tercel GTS is offline
Old 12-14-2003, 07:03 PM   #10 (permalink)
The engine is a 3.0 V-6, and I am still getting spark. It is the fuel delivery that is the problem.
Joe0606 is offline
Old 12-15-2003, 07:25 PM   #11 (permalink)
View Edgeman's Photo Gallery
Possible bad fuel pressure regulator
If you are sure it's a fuel problem, the first step is probable a failed fuel pressure regulator. The next step is probably a failed fuel pump. I'm assuming you have changed your fuel filter, but that shouldn't give you an "instant" poor running condition. You may also check to see if you have a failed fuel line thats spraying fuel and losing fuel pressure to the engine. I would say to hook up a fuel pressure gauge, but it's impossible to find one for a Toyota.
I had a similar feeling running problem with my 22RE, and it turned out to be one of my cogs had several broken teeth, and caused my timing chain to jump a tooth. That with only 84K on the odometer...
Good luck!
Edgeman is offline
Old 09-05-2004, 05:32 PM   #12 (permalink)
View Twams's Photo Gallery
I have the same problem
Did you find an answer? I do not get any clicking under the hood or fuel pump humm but when i turn the starter around i get power to the fuel pump.
Thanks,
Tom
Twams is offline
Old 09-08-2004, 10:01 PM   #13 (permalink)
View southside's Photo Gallery
i would do air flow meter test as per manual. also adj new tps to specs.sounds like a air fuel mixture problem if it runs at half throttle
southside is offline
