If yours is the V6, the starter can be accessed through the front passenger side wheel well. Just take off that wheel, rubber wheel well flaps and the metal tin plate there and unbolt the starter. Note that there are two bolts holding the starter there and one bolt might have been inserted through one side of the mounts and the other bolt through the other side. If this is not the case when you take out your starter, you may have to bolt on the starter this way as doing it the way of the factory Toyota manual (both bolts on one side) is nearly impossible to do.
1989 Toyota 4WD P-up Ext. Cab SR5 V6 Auto (currently out of commission)
2005 Dodge Neon SRT-4
- 11.9 @ 117 1.79 60' (best trap 120 mph)
- 30.8 mpg city/hwy (pulse & glide), 33.4 mpg hwy
- 178,000+ miles (still on original motor)
