wheels for 82 toyota pickup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2003, 07:12 PM   #1 (permalink)
View toyota4x4-12's Photo Gallery
I recently bought a 1982 toyota pickup and started going through it checking everything like the breaks, frame etc. And when i took the front wheels off there were many washers around each bolt to space the wheels out a little wider.I took them off to put a smaller set of toyota tires on (easier to work on b/c it came with 38's). Without the washers they rub on the tie rod ends. I am unsure as to if that year had different wheels or what? I am also debating on whether putting the engine from a 93 toyota (fuel injected) or keeping the carberated engine and maybe just puting diff carb or sumthing (i alredy have a header for it).
thanx for your help!
toyota4x4-12 is offline
Old 12-20-2003, 08:50 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
It sounds like your tires might be too wide for that amount of backspacing. You need narrower tires or rims with less BS.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
