22re Vacuum leak! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2003, 10:39 PM   #1 (permalink)
View extbike's Photo Gallery
Angry 22re Vacuum leak!
At idle my truck whistles. I have replaced the gasket between the plenium and the intake, not the problem. Any tricks as to how to locate the problem.
extbike is offline
Old 12-20-2003, 11:08 PM   #2 (permalink)
View rafiki's Photo Gallery
put a lil dishsoap in a spray bottle w/water and spray towards the sound. the soap will bubble when the air passes through it.
rafiki is offline
Old 12-21-2003, 02:00 PM   #3 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Or, you can use carb cleaner (or some other highly combustible substance) and spray where you think the problem might be.....when you find the spot, the engine will either increase or decrease in RPM.
However, when you replaced the gasket on the throttle body, did you use a cork gasket or RTV??? This might be your problem if you used cork....they tend to leak.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
