22-re advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-23-2003, 11:38 PM   #1 (permalink)
View mwabd1's Photo Gallery
22-re advice
Alright I need some direction here. I have a '91 4-runner with a 22-re. It has no ass!!! It accelerates very slow and has no power.
Here is what has been done. After my wife killed the motor for the third time in 2 years I yanked it and had it rebuilt, everything new except crankshaft. It ran good until the fuel rail cracked and the engine caught fire, and after that i replaced.............the following sensors, mass air flow, knock, t.p.s., temp. It also has all new fuel injectors, lines, etc. And the engine wire harness in brand new. So basically everthing under the hood in new except the egr valve.
I have set the tps per directions in the haynes.
Any ideas????????????
mwabd1 is offline
Old 12-24-2003, 11:13 AM   #2 (permalink)
Is it possible that the timing is not advanceing, or by some slim chance is it possible that the cam can be a tooth off?? I did take it to the local toyota dealer and they came up with nothing.
Hell if all else fails I might just have to shoe-horn a 350 in there.
mwabd1 is offline
Old 12-26-2003, 11:47 PM   #3 (permalink)
View 60chevy's Photo Gallery
Lightbulb
A couple years ago my 22RE started running bad, It would idle fine and run at 30MPH in 4th after that run bad and had no power, Like it was missing. After much whailing and gashing of teeth I found that the"surge valve" was bad. It's that little thing on the bottom side and front of the fuel rail, it has a plastic cap on it.
Good luck.
60chevy is offline
