Specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2003, 12:16 AM   #1 (permalink)
View CalPreRunner98's Photo Gallery
Specs
I'm a new owner of a 98TacoPreRunner 2wd and would like some info.
I tried posting this to the forum before but could not confirm it landed; please excuse me if it hits twice...
My Taco has a LiftKit installed which I would like to remove. It raises the truck 2.5 inches by putting a puck above the front spring perch, and using a longer shackle on the rear leaf spring. I'd like to put the suspension back to its stock ride height, and could use any info you folks can provide for specs or parts to replace the originals.
Thanks for your help!
New Taco Dude
CalPreRunner98 is offline
Old 12-27-2003, 04:46 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Remove the tires and jack up the truck so that the suspension droops......you should be able to droop each side enough to pull out the spring and remove the coil spacer. You might find a spring compressor useful (Auto Zone should "rent" you one). As for the rear, you'll need to find some stock shackles. They are fairly easy to install.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 12-27-2003, 11:35 PM   #3 (permalink)
Thanks JeremyH. Any idea where I should go to buy an original Owners Manual and a Toyo Shop Manual? I've been looking around the Toyo Official site but all they seem to want to sell is stuff for the 03 or 04 vehicle just bought.
Old 12-28-2003, 10:01 AM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
http://www.toyota.com/about/contact/index.html
JeremyH is offline
