Modding - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2004, 02:37 AM   #1 (permalink)
View n3m3s1sX's Photo Gallery
Modding
Can you mod 1989 toyota pickup stock, like you can a Honda. What type of engines can you do swaps with? Any info on engines, moding tips would help alot.
n3m3s1sX is offline
Old 01-14-2004, 05:46 AM   #2 (permalink)
TN's SRT-4
MenaceSQL's Avatar
View MenaceSQL's Photo Gallery
For the 4WD, the main swaps are either a small block chevy or a Ford 5.0L HO. Also I have heard of some other engines such as the 7M-GTE, the 7M-GE, the LT-1, and the 5VZ. That's all I can think of right now. For the V8's, I believe you have to throw a lift on the truck to get enough clearance and to get additional strength for the extra weight of the new engine.
1989 Toyota 4WD P-up Ext. Cab SR5 V6 Auto (currently out of commission)
2005 Dodge Neon SRT-4
- 11.9 @ 117 1.79 60' (best trap 120 mph)
- 30.8 mpg city/hwy (pulse & glide), 33.4 mpg hwy
- 178,000+ miles (still on original motor)
MenaceSQL is offline
Old 01-30-2004, 11:00 PM   #3 (permalink)
View dav940's Photo Gallery
mods
try www.toyotaperformance.com they have engine and turbo kits from stock all the way to racing stroker motors
dav940 is offline
Old 01-31-2004, 05:09 AM   #4 (permalink)
View justin22's Photo Gallery
3.4 chev, 3.4 toyota, 3.4 toyota w/ super charger, 3.0 toyota straight 6,3.0 toyota straight 6 turbo, 5.0 ford
those are the most popular ones, but what are you looking for if its for more power do go to nuts, toyota are strong but to much power and things start to break. If you put a good size motor in make sure the drive train can take it
Why Toyota, because I understand
justin22 is offline
Old 02-01-2004, 03:15 AM   #5 (permalink)
like what would you suggest for a toy pick up 2wd which one of those motors ?. I just want something that i can have some power but not to much that it will break.
n3m3s1sX is offline
Old 02-01-2004, 02:16 PM   #6 (permalink)
3.0 toyota straight 6,3.4 chev either one of them should be ok lots of power but not to much that you half to upgrade other parts
justin22 is offline
Old 02-04-2004, 01:16 PM   #7 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
http://www.automotivetalk.net/showmessages.php?id=633
http://yotatech.com/showthread.php?threadid=16644
-Nick
Nick is offline
Old 02-04-2004, 05:35 PM   #8 (permalink)
View mattH's Photo Gallery
i have a 89 pickup 22re and i screwd up.. for some odd resone i had the ignition on while i was doing this. i wanted to put a intake cone on my intake so i remove the box, and put the cone on the end of the intake hose. didnt start. ok i kno why is the mass air sensor so i try to un plug it, the plug woulden pull out so i unscrewed the plug end when i pulled it out something shorted and sparked so i put it back together. looked at th fuse and it melted so i replace it and now it fries all the fuses i put in the efi slot and will crank but not start. this sux
mattH is offline
