22R engine tick - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2005, 07:31 PM   #16 (permalink)
DCM
One with the farce
Gameroom cash: $106800
View DCM's Photo Gallery
Also, check the clearance between the rockers and the rocker shaft. If they are worn, they can slop around every time the cam pushes them up. I had a set that had even worn out the rocker shaft itself.
DCM is offline
Old 04-27-2005, 11:05 PM   #17 (permalink)
82toyo's Avatar
View 82toyo's Photo Gallery
I just put a new rebuilt 22r in my 82 toy and was freaking out about the ticking. My friend has a 83 toy and his does the exact same thing, just goes with the 22r.
82toyo is offline
Old 04-09-2006, 09:40 PM   #18 (permalink)
View ozzyman778's Photo Gallery
Originally Posted by 87_SR5
I adjusted my valves on my '87 22RE recently. When I checked the clearances before I adjusted them..they were really tight. Apparently they tighten up over time..from what i have read (the engine has 165K miles on it, and I have no idea when the valves were last adjusted...if at all). So I put them back to specs, started it up and got one good tick. You could definitly tell it was a valve.
I thought I screwed up, so I readjusted the valves again...but came back with the same results. I readjusted a few more times until I finally gave up. I read that this kind of tapping is normal for the engine, but I just didn't hear it before because the valves were too tight...
I did replace the valve adjustment screws (got them for about $2.50 each from 1sttoyotaparts.com...luckily that dealer is located close to me so no shipping charges ) After replacing all the screws, I still have the tap (doesn't seem as loud)....but I did notice the truck being a lot smoother upon acceleration. Here is a picture of my adjusting screws compared to a new one:
You can see the 'hourglass' shape. Notice one (red dot) is pitted..
I forgot I had this...sound clip of the valve tapping/ticking (before screw replacement): http://www.members.aol.com/jamy4us/truck/yota/tick.wav
I am struggling with something very similiar to this.... I recently purchased my truck.. A 92 Pickup with the 22re.... It had 105,000 miles on it and had a noticeable timing chain issue... I replaced it with a dual row timing chain, new cover, metal guides, and new tensioner. also installed a new water and oil pump while I was in there....
Everything went fine but now I can hear some valve noise.... So I adjusted the valves several times and never could get rid of it.... It sounds almost exactly like you're sound clip except not quite as loud. However it is loud enough to hear inside the cab with the radio off.... I will try replacing the adjusting screws.... thanks... anything else you think it could be plase let me know....
ozzyman778 is offline
Old 04-12-2006, 09:35 PM   #19 (permalink)
View MAXIMUS1968's Photo Gallery
If i change the screws out on the rocker arms i will have to have the valves readjusted??????.........Correct?
MAXIMUS1968 is offline
Old 04-13-2006, 07:30 AM   #20 (permalink)
View jimscat's Photo Gallery
Isn't the timing chain tensioner oil driven? Hence a tick untill oil pressure builds
93 Toyota PU 4x4 Extended cab, 22RE, 5sp
100,000 miles.
jimscat is offline
Old 04-13-2006, 10:18 AM   #21 (permalink)
View nikita's Photo Gallery
What I dont think has been stated in this thread is that the 22r (unlike the 20r) had aluminum rockers. They tend to amplify noise. I had an '84, purchased new. There was always a little clatter that my brother's '79 didnt have. 22r-powered Celicas had the same noise, but car owners complained a lot more about it than truck owners did.
nikita is offline
Old 04-13-2006, 03:08 PM   #22 (permalink)
oil pressure builds quite quickly..... the ticking is constant
