Won't crank hot intermittently - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2004, 07:23 AM   #1 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Got a '86 4runner about 6 months ago. Runs great, but after driving long distances or short on/off errands, it won't start/crank. Getting low voltage to starter solenoid. Checked and replaced solenoid contacts, replaced open circuit relay and replaced neutral safety switch. Still have intermittent problem. Any ideas where else to look.
texas12 is offline
Old 01-25-2004, 10:33 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
I'd wire in an extra relay myself. It'd be a lot easier than running down the weak connection. Get a heavy duty relay from a stereo shop and wire something like this;
....................ignition wire currently going to starter
...battery wire at starter--no connection--ignition terminal of starter
...........................................ground
buy here
雄のハヤブサ
Tercel GTS is offline
Old 01-26-2004, 04:21 PM   #3 (permalink)
texas12's Avatar
Thanks for the post. Actually I have it rigged right now with a hot wire switch. I have a wire from + battery post to push botton switch on dash and back to starter solenoid. When it doesn't start I just leave the key ON and push the button. However, I have been determined to track down the real problem.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
