Performance Mods??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-11-2004, 02:46 PM   #1 (permalink)
View ill_0ne's Photo Gallery
Performance Mods???
Wsup there,
Just wanted to know the best performance mods for a semi-new tacoma, other than supercharger or headers. Something relatively small in price but noticable in performance. I was think of spark plugs and spark plug wires? any ideas for type brands to get? any help would b appreciated thanks. peace
03 Tacoma TRD v6 4wd
k&n intake
cf tail lights
pre-runner light bar
flowmaster cat-back exhaust
ill_0ne is offline
Old 02-11-2004, 04:26 PM   #2 (permalink)
View justin22's Photo Gallery
NKG wires, Toyota plugs, change you diff fluid as well, castrol syn
Why Toyota, because I understand
justin22 is offline
Old 02-11-2004, 05:09 PM   #3 (permalink)
thanks justin but i heard if you use reg. oil its not good to go to synthetic oil is this true or not? as far as the nkg wires n toyota plugs those sound good. thanks
k&n intake
cf tail lights
ill_0ne is offline
Old 02-20-2004, 01:30 AM   #4 (permalink)
***CrAzY SOB***
turbo17's Avatar
View turbo17's Photo Gallery
Thumbs up
If you want some extra juice to those wheels and a little chriping I say go with the LC Engineering light weight flywheel I think it is around 8 lbs or so. And Bosch plugs are just as good if not better. Go with a K & N intake system and a good cat back exhaust Flowmaster or TRD.
turbo17 is offline
Old 02-20-2004, 06:30 AM   #5 (permalink)
I've had the Bosch plugs and I found that they hurt me more then anything else.
As so for syn oils, it shouldn't be a problem, I've used it in all my rigs, newest I had was a 93, never had any oil leaks or problems. The people who say its bad for your rig are full of it.
It takes for ever to break down, so it last longer and it is easyer on your motor, and its lighter.
justin22 is offline
Old 02-20-2004, 09:49 AM   #6 (permalink)
Official TN Memburr
D'mon's Avatar
View D'mon's Photo Gallery
I have not run synthetic in any of my four wheeled transportations, but I run Mobil 1 in my bike. It is easier to start in the cold and is far superior in protection.
Keep in mind, oil filter should still be changed every 3000 miles, although the oil can be good for about 5-6000 miles. Oil leaks are an issue, but do not create leaks- it only runs easier from existing leaks. Don't use it in a leaky engine.
Also, do not use in a new engine, as in still in the break-in period. Rings will not seat while you run synthetic, so your compression sucks and the engine never runs properly.
As for syn gear oil, I have no opinion having never used it. I am looking into it as we hit -57 degrees this winter and I found the tranny just did not want to move much. I'd like the superior true viscosity you get with synthetic.
D'mon
D'mon is offline
Old 02-20-2004, 11:43 AM   #7 (permalink)
thanks for the options i'll look into it. thanks for the help
k&n intake
cf tail lights
ill_0ne is offline
