The main problem is with the Aisin carb is the AAP diaprhram. A leaky one can cause fuel washdown, and the extra gasoline can remove enough oil from the piston walls to increase cylinder wear dramatically. The AAP can be accessed on the outside of the carb. The AAP (AUXILLARY accelerator pump) in proprer running engines is only used when the engine is cold.
Seeing that the volume of fuel in the crankcase is enough to be seen on the dipstick, you want to look at a bad mechanical fuel pump. A leaky diaqphram here can definitely allow enough gasoline to drain into the head, and down to the crankcase.
Fuel plugs like the Q-jet, may be present on the Aisin, but after reading thousands of posts, this has never been a problem. I have yet to rebuild the carb on my 1984 22r 4x4.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
