Signu is right about the relay, allthough it is a bit pricy.
Heres what you should do before droping cash into it; First pull the starter relay out & remove its cover then put it back in without the cover and watch to see if it clicks on and off if it dosnt work dont go rushing out for a new one just yet.
the clicking you hear in the dash is most likely the ecm relays and circuit breakers coming on an off. Next, that modle truck is famous for black wire disease, so remove the battery and strim the outer coating off of the battery cables and I mean all of it, just one small spot will stop enough current flow from reaching the starter since you can build that voltage on the resistance. Once it is striped down, clean any and all corosion off the cable with mild to light emry paper (about 400-600 grit) NOT sand paper, and do the same to any area that has a black oxadised look to it. Now you want to use denatured alcahol, like break clean and spray all exposed wire with it and whipe off any residue and dirt. Now see if it wont turn over. If it dose go ahead and get some Wire insulator, just that plastic/rubber shring wrap for wiring and use a hair dryer or something of the sort to shrink it tight around the wiring (No open flames, thats bad) go ahead and make a nice even cover on both ends of it with some electrical tape, and go ahead and use a bic lighter to slightly heat (but not burn or melt) the tape and you should be better sealed than before.
Now this part is NOT recomended but I do it for myself is tape the shit out of the battery cable fittings so that only the actual round part of the fitting is exposed, I just dont like to see any corosion on them.
