94 22re No Spark - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2004, 11:25 PM   #1 (permalink)
View meeatch1's Photo Gallery
94 22re No Spark
I have 94 Toyota p/u 22re motor that won't start. It'll turn over, but won't fire. I tried a new coil, no luck. I tried new cap, rotor, wires and I even got a used igniter from a wrecker, and still no spark. Anybody have any ideas? It's raining out here and I'm getting sick of riding my motorcycle to work. Any ideas are appreciated.
Mitch
meeatch1 is offline
Old 02-21-2004, 05:58 PM   #2 (permalink)
View Rycam's Photo Gallery
There is a small pickup-coil in the disributor that can fail. It is the electrical device that the four-tooth cam swings past. The ignitor takes this small signal from the pickup-coil (also called a signal generator), and generates a 12V signal to be sent to the coil. A multimeter cab be used to see if the pickup is within specs. I do not know the Ohm reading you need but you can check a typical Chilton's manual for this.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 02-21-2004, 07:21 PM   #3 (permalink)
Official TN Memburr
D'mon's Avatar
View D'mon's Photo Gallery
Unhappy
Consider yourself lucky to be able to ride your motorcycle now. I still have 3 feet of snow to melt before I can ride. The last time I rode was November...
D'mon
{in the wonderful city of Winterpeg}
D'mon is offline
Old 02-23-2004, 12:24 AM   #4 (permalink)
Thanks for the tip.
My friend had me turn the ignition while the distributor cap was off, and the rotor didn't turn. I pulled the distributor and the shaft was okay, telling me that there is a much more serious problem, like a broken timing chain or camshaft. I'll let you know how it goes when I take a look inside.
BUMMER
By the way, I'm stoked to be riding my moto, but I'd have even more fun on a snow-mo.
meeatch1 is offline
Old 11-10-2004, 12:00 PM   #5 (permalink)
View 91toyindiana's Photo Gallery
its yo ur chain for sure... might wanna get a timing kit ca use the timing guides go bad.
91toyindiana is offline
