Oil Pressure guage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2004, 10:33 AM   #1 (permalink)
View ant007's Photo Gallery
Question Oil Pressure guage
Can some help me. I have an 03 Sequoia with 16k miles on it. The oil pressure guage goes up and down along with the rpm. Is this normal? Shouldn't the oil pressure be constant in the middle of the gauge? I never notice this before. Thanks in Advance. Ant
ant007 is offline
Old 02-24-2004, 11:27 AM   #2 (permalink)
View smokinjoe3's Photo Gallery
Your oil pressure should be in the normal band at all times, but does go up and down with rpm. That is normal.
~smokinjoe3
smokinjoe3 is offline
Old 02-24-2004, 04:00 PM   #3 (permalink)
Thanks smokinjoe3
ant007 is offline
Old 03-01-2004, 07:38 PM   #4 (permalink)
View DUBCAB's Photo Gallery
I took my mom's sequoia in to the dealer for the same thing and they said it was a bad sensor, so they fixed it for free.
DUBCAB is offline
Old 03-02-2004, 08:29 AM   #5 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Did yours go all the way to zero? If so, that is a bad oil sending unit. That is what they replaced.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 03-08-2004, 06:38 PM   #6 (permalink)
It would go up and down all the way with accelaration and braking.
DUBCAB is offline
Old 03-12-2004, 12:22 PM   #7 (permalink)
View wight tale deer's Photo Gallery
it could be a weak oil pump get it checked!
wight tale deer is offline
Old 03-13-2004, 04:57 AM   #8 (permalink)
toy283's Avatar
View toy283's Photo Gallery
I'd be more worried if the pressure stayed constant. As engine speeds increase so will oil flow. The clearance space for the oil to flow remains the same. If you try to cram more oil through the same space, pressure should naturally go up. If it doesn't, it might imply that clearances are greater than they should be.
Dave
'84 XCab, blown 283 V8, SM420, dual cases, etc.
'85 4Runner
home.comcast.net/~toy283
toy283 is offline
