Originally posted by Aj_26
I took my truck to a dirt road where there were uneven surfaces. My truck was rocking side to side as if there were no springs or shocks. I thought I was going to tip over.
So it takes a long time to stop bouncing after you hit a bump? If so, then yeah it sounds like you need new shocks. I thought you meant the ride is really stiff. The TRD shocks for the regular cab and extra cab are bilsteins, although I've heard they're not as good as the aftermarket bilsteins. The double cab TRD comes with tokico shocks.
If you're going to lift it like you said in the other thread, then go for some OME shocks and springs. They will take care of the undamped oscillations, but be aware the ride will be stiffer.
