Originally posted by HandsomeRobb
i dont know but i thought the higher octane burned faster because of the more of equivelent of octane molecules?
Half right. It is more eqivulent to octane molecule but that means it burns slightly slower than regular (which has more lower molecular weight compounds like benzene, etc). This allows higher compression ratios in the cylinder with less risk of preignition (knocks or pings). Higher compression means more power. Higher octane means smoother running engines.
If your engine isn't knocking or running rough, you don't need the high octane fuel. (If it is knocking or running rough, you need a tune-up, not higher octane.) I never use anything but regular since my cynical view is that all the gas pumps suck out of the same underground tank anyway.
Why pay more for the same stuff?
