Shudder in reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2004, 08:01 PM   #1 (permalink)
View Highland boy's Photo Gallery
Unhappy Shudder in reverse
Have a 1993 Toyota ext. cab truck with 4 cyl. auto and 220,000 Km. I am getting a shudder when the truck is put into reverse. The shudder or vibration can be felt in the steering wheel and the front fenders. I get this only when the truck is under a load, for example, backing up a hill. I can mimic the condition by putting the tranny in reverse, holding the brake on and reving the engine slightly. I suspect a problem with a transmission band (adjustment needed?) or a clutch? Wondering if anybody has had a similar problem or knows what the problem is. Help is greatly appreciated.
Highland boy is offline
Old 02-27-2004, 10:03 PM   #2 (permalink)
View justin22's Photo Gallery
when was the last time you had your brakes adjusted on the rear
Why Toyota, because I understand
justin22 is offline
Old 03-03-2004, 09:22 AM   #3 (permalink)
Rear brakes are adjusted up. Not sure how this could cause my problem. Could you explain?
Old 03-03-2004, 03:07 PM   #4 (permalink)
if the brakes stick on they will slip inside the drum.
justin22 is offline
