how do i change brake rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2004, 11:54 AM   #1 (permalink)
View clicc916's Photo Gallery
i'm a newbie to toyota trucks...so i started checking out my friend's truck and found out i needed to change his front rotors and pads...i'm ok with the changing the pads, but how do i change the brake rotor? he has a 1993 4x2 v6....need to finish this asap...pics would help a lot if possible, thanks
ps- i did a search but couldnt find anything relevant
clicc916 is offline
Old 03-13-2004, 05:19 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
When you pull off the brake caliper, the rotor should just slide off after you remove a few bolts. Sometimes they are rusted on....but nothing a hammer wont fix.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
Old 03-16-2004, 10:05 PM   #3 (permalink)
View SpeshalK_82's Photo Gallery
i just recently changed front wheel bearings in my toyota and a friends. Once you take the caliper off, take the dust cap off of the spindle. There should be a cotter pin in the end and then a lock nut and an adjuster nut. Once you remove the pin and the nuts the rotor should slide off the spindle.
SpeshalK_82 is offline
Old 03-23-2004, 03:50 PM   #4 (permalink)
View VULLER's Photo Gallery
ROTOR
LIKE THE OTHER FELLOW SAID REMOVE THE COTTER PIN THEN REMOVE THE NUT THEN YOU HAVE TO REMOVE THE HUB FROM THE ROTOR , THOS YOU NEED IMPACT GUN EITHER ELECTRIC OR AIR LIKE THE ONES SHOPS HAVE THERE ARE FIVE BOLTS YOU GET THEM OUT AND THERE YOU HAVE YOUR OLD ROTOR, PUT ON THE NEW ROTORS AND REVERSE THE PROCCESS GOOD LUCK
VULLER is offline
