Quick/Affordable mods to get horsepower out of a 22RE? ANYONE?!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2004, 12:15 AM   #1 (permalink)
View RayDogg30's Photo Gallery
Hey Everyone,
My name is Ray and i have a 22re. I was wondering if anyone knows a quick and cheap way for me to gain a few horsies. I just want a little more power so i can tow more stuff. Anything helps with a 4 banger. Thanks
-RAY
1996 Taco Xtra cab 3.4L and a 1990 22RE Xtra cab...gotta love em'
RayDogg30 is offline
Old 03-15-2004, 12:19 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
a cold air intake is pretty cheap to make and would give you a bit more cheap power
also if you havent changed your spark plugs, ignition wires and distributor cap in a while those could help, pretty much a basic tune up never hurts
-Nick
Nick is offline
Old 03-15-2004, 12:25 AM   #3 (permalink)
:D
When it comes to cool air im an idiot. I am intimidated by that little black air sensor and i think that if i mess with it i will fry my computer..how do i get the cool air intake on and not disrupt that sensor?
Thanks
-RAY
Old 03-15-2004, 12:28 AM   #4 (permalink)
Nick's Avatar
as long as its in the airflow it shoudl be fine
others just drill a bunch of holes in the dirty air side of their stock air boxes (not really the best idea though)
-Nick
Nick is offline
Old 03-15-2004, 12:34 AM   #5 (permalink)
:D
I have also heard about this kind of "restrictor" or some thing that plugs into your mas air flow censor...it makes your computer think the air is a lot colder than it really is? Or something like that. I was wondering if you could explain that to me so i can try it if it really works. I guess it makes the comp think it is a lot colder air being sucked into the intake..so it sucks a lot more, a lot faster. Is this a bunch of B/S? Thanks.
-RAY
Old 03-15-2004, 12:51 AM   #6 (permalink)
:D
Also i was wondering if a header would mess with the computer in my truck. Just a thought. Anything helps. Thanks.
-Ray
Old 03-15-2004, 02:05 AM   #7 (permalink)
Nick's Avatar
header shoudln't do anything,
those resistors that make your car run rich, well they're pretty much a waste of money
-Nick
Nick is offline
Old 03-16-2004, 12:17 AM   #8 (permalink)
Offical nut
redfox435cat's Avatar
View redfox435cat's Photo Gallery
do u have a cold air intake that really increases horsepower? I've been tuning vw's for a few years and every cold air intake would simply create a cool tone but lose about 1 hp
4x4 v6 04 tacoma
Your Driving?Were we going?
redfox435cat is offline
Old 03-16-2004, 12:45 AM   #9 (permalink)
***CrAzY SOB***
turbo17's Avatar
View turbo17's Photo Gallery
1st off what vw's have you been tunning? You can lose power if you constantly suck in hot air...which is probably what your intake on your vw was doing. Depending on the year most don't have a (air ram system) that allows COLD air to go to the intake filter. A cheap way of doing it...get some flex tubing about 3" run it from the grill or tire (fender wheel) then up right by the filter. This will allow a ton of COLD air to the intake and you should actually gain hp. Atleast 10hp maybe up to 25hp depends on engine, weather, etc.
turbo17 is offline
Old 03-21-2004, 11:16 AM   #10 (permalink)
View mbradbury's Photo Gallery
Ram air
Ram air starts to become effective (IF properly designed) at speeds ABOVE 100 mph
Cold air intakes are NOT ram air.
mbradbury is offline
Old 03-29-2004, 05:41 PM   #11 (permalink)
View johnisenglish's Photo Gallery
Having your intake open to the front of the car won't force more air into the intake, it violates the laws of fluid dynamics. What will happens is once air is filling your intake faster then the engine can draw it in, the intake will be a high pressure area relative to the air around it. As a result, incoming air will flow around that area into the surrounding, lower pressure areas. You'll never be able to get the air pressure in a naturally aspirated intake above 0psi, or atmospheric pressure.
When you hear about Automakers or racing teams talking about "Ram-Air" they're referring to a process in which the size and shape of the runners in the intake manifold can cause very small, very fast pressure waves that can actually slightly increase the air pressure of the intake charge right at the intake valve(s) at a certain rpm. That can't be applied to the whole powerband without variable length intake manifolds (as seen on the new RX-8), and has nothing to do with making the opening on the intake face the front of the car.
As far as cold air intakes go, there is power to be had there, but you're going to be very hard pressed to be able to get any large power gains by moving the filter and putting in a metal pipe. The Toyota engineers would have to be pretty incompetent to so poorly design the stock intake that it reduces the power of the engine by 15 - 20hp, and as a result gives it worse gas mileage. True, there are other factors involved such as ease of access for maintenance, sound reduction, etc, but its simply not going to be that much of a power drain.
For other easy and "affordable" power mods, it depends on what your definition of easy and affordable is. Opening up the exhaust from the engine back (header, cat, exhaust) is always a good idea, but its only going to go so far. If you're looking for big power chances are you best bet (and cheapest) is going to be to do an engine swap or go with Forced Induction.
-93 RX-7
-94 Toyota Pickup
johnisenglish is offline
Old 04-18-2004, 10:02 PM   #12 (permalink)
Fat
View 96tacoma's Photo Gallery
Re: Ram air
Thats true, but what the tube does bring cooler air to the the intake which increases the horsepower.
Its a Toyota thing, you wouldn't understand.
96tacoma is offline
Old 04-19-2004, 01:03 AM   #13 (permalink)
Re: Re: Ram air
Which may or may NOT increase the hp.
Fact is, most seem to think it's a sure thing, it's not. Opening a bigger or more direct path SEEMS like it would have to help. But if it instead opens up a path for hot underhood air INSTEAD of cooler outside the vehicle air, then it isn't going to help at all.
Old 04-22-2004, 09:16 PM   #14 (permalink)
Fat
Talking Re: Re: Re: Ram air
Thats very true, the only reason I said that was because i did it to my tacoma. I put the k&n intake on it and ran a tube from the opening in the air dam to the side of the inner fender were the snorkel used to be.
96tacoma is offline
Old 04-25-2004, 12:38 AM   #15 (permalink)
Re: Re: Re: Re: Ram air
ahhhhh
