red maniflod/ 22-re problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2004, 03:56 PM   #1 (permalink)
View 88toyotaboy's Photo Gallery
Im having some serious problems with my 88 toyota 4x4 22-re fuel injected. It has no power. Going uphill i can get the rpm up at all and have to stay in first and cant get it to shift without the rpms dumping. There is very little acceleration even on the flats. It does have 32x11.50 tires with stock ring and pinion.
Oh
And the exhaust manifold turns red after driving for short distances or up hills.
Please Help?
88toyotaboy is offline
Old 03-18-2004, 03:01 AM   #2 (permalink)
View superjoe83's Photo Gallery
i would check for a plugged cat, take the cat off and go for a short drive, it will be loud but if you got power, then your cat is plugged up, if its the same then you got another problem, either timing or fuel.
superjoe83 is offline
Old 03-18-2004, 02:30 PM   #3 (permalink)
i already took car of the cat and that isnt it and i checked the timing too.
Old 03-18-2004, 02:42 PM   #4 (permalink)
Official TN Memburr
D'mon's Avatar
View D'mon's Photo Gallery
What color are the plug electrodes and such? Maybe it's running way too lean.
D'mon
D'mon is offline
Old 03-18-2004, 10:49 PM   #5 (permalink)
The plugs look normal, but we think that mixture is not lean enough because of carbon deposits that we found after taking the exhaust manifold off.
Old 08-24-2004, 07:58 AM   #6 (permalink)
View tomandjobeth's Photo Gallery
Was this ever resolved?
I am having the exact same problem with an 88 22-RE 4WD Toyota pickup. Did you ever figure out what was causing the lack of power?
Any help is appreciated! Thanks.
Tom
tomandjobeth is offline
Old 08-24-2004, 08:38 PM   #7 (permalink)
It turned out that the timing was waaaayyyy off. That caused it to not only have zero power but also the manifold to glow. If that is the problem on your truck after you fix it it will be a whole different truck. Good luck on figuring it out and if the timing isnt the problem i would go to
yotatech.com they have been more help to me than toyota nation was...
Old 08-27-2004, 09:09 AM   #8 (permalink)
View ripcurl's Photo Gallery
Check your truck for trouble codes, mine ran the same way, turned out the idiot that owned the truck before me had jammed in the knock sensor connector incorrectly, and the truck had zero power. I'd have to downshift to third to make it up a hill, after doing 55 on level ground. Either that or it's the timing.
ripcurl is offline
Old 08-27-2004, 04:54 PM   #9 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
^ he alread said it's the timing. It's fixed now....
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline
