Your V-6 problem
Having the same issue. Have narrowed it down to the cold start injector (doubtful), the timing unit near the injector (doubtful), ECU (most probable) or the relay above the ECU. Talked to a pretty good mechanic on this and he says it is 50/50 on the ECU. Reason I know all this is check out all the timing components, was getting white smoke, advanced 20 degrees to start and limp home, and all the marks on everything and TDC lined up. One other thing. Sometimes the rotor cap can crack and short to the distributor to that is a cheap check. If you can get an ECU out of a clunker and check... Get a Haynes book and look at what is in the ECU circuit. Also, the book has all the resistances to check the pickupcoil, igniter, etc.
