4 speed to 5 speed trans swap 87 toyota truck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2004, 05:01 AM   #1 (permalink)
View fooks's Photo Gallery
does anyone know what it takes to swap a 4 speed to a 5 speed in my 87 toyota pickup 2wd standard cab with a 22r motor? does the trans tunnel have to be cut and a different lenght drive shaft needed. or is it a direct bolt in? what would be the best year trans to install.
thanks for any posts.
fooks is offline
Old 06-15-2006, 12:21 AM   #2 (permalink)
View suprpntr's Photo Gallery
Can anyone answer this question?
suprpntr is offline
Old 06-19-2006, 09:03 PM   #3 (permalink)
Toyota Fixer
View Jesster1's Photo Gallery
If you are just going to go from 4 speed to 5 speed there are no modifications necesary. If you go with the more desirable Celica 5 speed then you do have to modify the shift handle but otherewise its just a direct replacement.
Jesster1 is offline
Old 01-15-2008, 12:45 PM   #4 (permalink)
View peanut's Photo Gallery
Ok, good question. I found a 1987 5 speed for my 88 4 speed truck. I wont have to hack the tunnel then. That's great news. Is there anyway I can check the used trans before I go through all of the hassle of putting it in? Thanks.
peanut is offline
Old 01-19-2008, 10:05 AM   #5 (permalink)
Benwill1
benwill1's Avatar
View benwill1's Photo Gallery
Check the input shaft to see if you can pull it out and push it in. Don't be alarmed if you can push it up and down a little, but you don't want it to move in and out very much at all. You should be able to put it in all gears and listen a little, not the best test, but better than nothing. Listen to 5th.
'80 Toyota street/mud bog racer-22r/20head/bigssvalves/38mm dges Weber/header/Weisco pistons/stock bore,crank,rods/Scneider cam/4.30 gears/88(wider)rear/locker/36" tires
'84 4x4 extra cab/weber/header/Crane-12cam
RARE '85 4x4 auto/EFI. Not drivable(rod knock, missing parts)
benwill1 is offline
Old 01-19-2008, 08:49 PM   #6 (permalink)
Guys, is 1st any lower? I can't find a gear chart anywhere for the 4 and 5 speed.
peanut is offline
Old 01-19-2008, 10:08 PM   #7 (permalink)
Benwill1
benwill1's Avatar
See if this helps
http://www.4x4wire.com/toyota/faq/parts/
benwill1 is offline
Old 01-20-2008, 05:35 AM   #8 (permalink)
Mine is a 2 wheel drive. Also, that site does not list a 1988 as having a 22R, but a 22RE instead. Mine is carbed.
peanut is offline
Old 01-20-2008, 10:30 PM   #9 (permalink)
Benwill1
benwill1's Avatar
I didn't even think about the 2wd part..sorry. I think they stop putting the carb in the 4wd earlyer than the 2wd.
benwill1 is offline
