vibration in 4 wheel drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2004, 10:47 AM   #1 (permalink)
View 95Supra's Photo Gallery
When I put the truck into 4 wheel drive I am getting a driveline vibration above 20mph. It's not a steering wheel vibration, more in the driveline when I'm on the gas. Does anyone have a suggestion where I should start to look?
Thanks
95 Supra n/a
94 Toyota 4x4
95Supra is offline
Old 04-06-2004, 12:59 PM   #2 (permalink)
View wight tale deer's Photo Gallery
do you have to lock it in at the front wheels? if you do try to look at the drive shaft and see if it is balanced
wight tale deer is offline
Old 04-06-2004, 02:16 PM   #3 (permalink)
Yes, I do have to lock the front hubs. How will I tell if the driveshaft is balanced.....weight on it?
95 Supra n/a
94 Toyota 4x4
95Supra is offline
Old 04-06-2004, 10:18 PM   #4 (permalink)
Offical nut
redfox435cat's Avatar
View redfox435cat's Photo Gallery
whens the last time u tightened and greased the propeller shaftes and driveline?
4x4 v6 04 tacoma
Your Driving?Were we going?
redfox435cat is offline
Old 04-07-2004, 06:43 AM   #5 (permalink)
I try that tonight. I haven't done anything with the truck, I just bought it last month. Where do I tighten the propeller shaft?
Thanks
95 Supra n/a
94 Toyota 4x4
95Supra is offline
Old 04-08-2004, 01:02 AM   #6 (permalink)
Offical nut
there are 4 bolts on either end of the driveshafts(propeller shafts) one to the rear diff one out the transfercase to the front diff. If its the 3 joint type then there are 12 bolts and 2 grease jerts at each connection.
the propeller shafts could also be out of ballance how
or the problems in the book say
transmission extension housing rear bushing worn ( only in 4x4 so that probably not it
sleeve yoke spline is stuck.
propeller shaft run out. not sure what that means.
tightening and greasing the drive shafts are suposed to be done every oil change and is something few people do. 9 out of 10 times u just need to tighten and lube it.
4x4 v6 04 tacoma
