Chevy? toyota wheel swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2004, 08:16 PM   #1 (permalink)
View reko95's Photo Gallery
I have heard that a chevy 6 lug wheel pattern is the same as a toyota 6 lug wheel pattern, is this true? Thank you for any advice.
reko95 is offline
Old 04-28-2004, 11:29 PM   #2 (permalink)
View Rycam's Photo Gallery
I have heard the same, as long as hole in the center of the wheel is large enough to fit over the diameter of the front hubs.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 04-29-2004, 12:57 AM   #3 (permalink)
View snobdrblinkchik's Photo Gallery
they are the same bolt pattern but the center bore size isn't the same...
snobdrblinkchik is offline
Old 04-29-2004, 06:43 PM   #4 (permalink)
True, True...a GM/Chevy FACTORY wheel may not fit. A lot of aftermarket wheel manufacturers make the larger hole size to fit as many vehicles as possible (and recycle the aluminum removed from the center).
Rycam is offline
Old 07-04-2004, 02:41 PM   #5 (permalink)
View Nimbly's Photo Gallery
I have heard that all 6 lugs you will come across will be the same pattern. I am not sure if this is true though.
Driving IS a right, one that should be
fought for if ever infringed.
Nimbly is offline
