Is it easy to change shocks on your own? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-28-2004, 10:23 PM   #1 (permalink)
View pt00323i's Photo Gallery
Wanted to see if any of you have changed your own shocks.
if so is it worth doing it yourself?
1992 Toy excab/5sp/2x4
pt00323i is offline
Old 04-29-2004, 12:56 AM   #2 (permalink)
View snobdrblinkchik's Photo Gallery
rear shocks r easy....for front you'll need a coil spring compressor...but they're kinda dangerous if you don't know what you're doing....
snobdrblinkchik is offline
Old 04-29-2004, 01:54 AM   #3 (permalink)
View 4x4yota's Photo Gallery
you won't need a spring compressor for either front or rear... it's a straight forward swap, remove and replace.
4x4yota is offline
Old 04-29-2004, 11:15 AM   #4 (permalink)
is this in the chilton's manuals? or is there a dIY website?
thanks
pt00323i is offline
Old 04-30-2004, 03:10 AM   #5 (permalink)
thanks
yes it's in the chilton's manual... just look under your car, you see the spring and shock are a seperate unit, they're not macpherson type shocks.
4x4yota is offline
Old 04-30-2004, 02:30 PM   #6 (permalink)
robinhood150's Avatar
View robinhood150's Photo Gallery
You don't need a manual, just look under there and you'll see. There are 2 bolts and/or nuts that hold on each shock. Just take them off and put on the new one. Be sure to soak the nuts/bolts in penetrating oil for a couple days first.
'93 4Runner V6 Auto 4x4
Robinhood's Lair.
robinhood150 is offline
Old 05-09-2004, 03:26 PM   #7 (permalink)
View CU@DCrest's Photo Gallery
If you got a 2wd, no problem and very easy, don't need a manual for a simple work like this. And 2wd have a torsion bar that you don't need to worry about any spring compressor. I've change all four shocks in less than 1/2 hour.
CU@DCrest is offline
Old 05-09-2004, 11:56 PM   #8 (permalink)
thank you all for the reply.
I'll spray them down with wd40 for a week or so. Then I'll install the new one.
pt00323i is offline
