If you do not regear your truck with 35's...YOU WILL BE ABSOLUTLEY MISERABLE!
If you don't believe me, you need to believe the engineers that originally designed your pickup. The Federal Gov't is all over ALL manufacturers to increase gas mileage. If they felt they could have gotten away with a lower-numerical gear (same as a your present gears with 35" tires) ...they would have!
I bought my old-ass 1984 in1994 with 32" tires, and the experience was hateful. Third gear took foreeeeeeeeeeeever to climb out of. A later set of 30" tires was 2" shorter, and the driving experience was much improved. After that set wore out, I went with a 28" tall tire. What a revelation!!! The tranny could now shift where it was designed to run!!! Smaller engines found in Toyota trucks need to matched to the gearing ratio that engineers wisely chose. A taller tire requires a gear change.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
