22R keeps cutting out want to know whats up ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2004, 09:38 PM   #1 (permalink)
View Kliff's Photo Gallery
My truck keeps cutting out when I let off the gas and it is really pissing me off ... It is a carburated 22R if you have any great suggestions let me know.. Thanks
Kliff is offline
Old 05-13-2004, 06:54 PM   #2 (permalink)
View brian83's Photo Gallery
Fuel filter?
brian83 is offline
Old 05-14-2004, 12:05 PM   #3 (permalink)
View SpeshalK_82's Photo Gallery
Does the engine die when you push in the clutch? I'm having the same problem with my truck. It starts cutting out when I'm driving and then dies when I push in the clutch at a stop sign. I haven't figured out the problem. But I've ruled out fuel filter, clogged fuel lines and a vaccum leak, but those are things you can check.
Speshal K
SpeshalK_82 is offline
Old 05-16-2004, 04:12 AM   #4 (permalink)
canon's Avatar
View canon's Photo Gallery
The fuel filter is more of a problem when you accelerate, not stop, so that is probably AOK. Check or replace your distributer cap and rotor. That usually fixes that problem on my 1989 22R. After that new plugs or new ignition cables if your ride is as old as mine. I've had your problem a couple of times with mine and the above fixed it. When you say 'cutting out' do you mean sputtering or the engine dieing ?
canon
canon
canon is offline
Old 05-17-2004, 10:07 PM   #5 (permalink)
View walter's Photo Gallery
what do you mean by cutting out .
how long after you turn it on .
how many times in a day does it cut out .
on hills or on flat ground.
walter is offline
Old 05-17-2004, 10:09 PM   #6 (permalink)
oh by the way how long have you own your truck?
walter is offline
Old 05-18-2004, 12:25 AM   #7 (permalink)
I was able to fix it
All I did was adjust the idle on the carb and now it runs perfect. Thanks for all your coments. Hey does anybody know where to get a new carburator for a 22R engine if you know please reply thanks.
Kliff is offline
Old 05-18-2004, 10:19 PM   #8 (permalink)
check out www.lcengineering.com
Old 05-28-2004, 02:35 AM   #9 (permalink)
canon's Avatar
Good job Kliff ! ! Glad to hear you got it goin !
canon
canon
canon is offline
