Changing trans & diff fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2004, 08:33 AM   #1 (permalink)
View hatrabbit's Photo Gallery
According to the service schedule for my '03 Tacoma 2wd, unless the vehicle is used under harsh conditions the tranny & rear end fluids never need changing. Do you guys agree? What rules of thumb do you use?
hatrabbit is offline
Old 05-31-2004, 11:26 PM   #2 (permalink)
View snobdrblinkchik's Photo Gallery
WTF??? Where does it say that in the manual? anyways I change my tranny (manual) every 30k....rear diff 20k, front diff 30k
it's all very easy to do...just make sure you take off the fill plug before the drain plug...cuz if you do the drain plug first, and for some reason can't get the fill plug off, you'll have an empty diff/tranny that u can't refill and that's not good
snobdrblinkchik is offline
Old 06-07-2004, 10:26 PM   #3 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Here, this is for a jeep, but it should work in your case as well:
http://www.stu-offroad.com/misc/diff-1.htm
BTW, I change the fluid in my diff's every six months. If you run through deep water, it is also a good idea to drain and fill the diff's as axle seals can easily leak and let water in.....which isnt good for your gears.
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline
