86 Toyota P/U Won't Start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2004, 10:18 PM   #1 (permalink)
View PNEALE's Photo Gallery
This truck suddenly quit starting. It has 190K miles. It was running/starting quite well. Getting gas, spark; timing chain looks new. Could it be an oxygen sensor? I tried squirting starting fluid in intake to no effect. You can hear it firing but it just won't catch, it won't keep running. Distributor cap looks new. Any comments welcome. Thank You.
PNEALE is offline
Old 06-07-2004, 07:23 PM   #2 (permalink)
View Rycam's Photo Gallery
22r (carb) or 22re (efi) ?!?
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 06-07-2004, 09:56 PM   #3 (permalink)
View slacker1's Photo Gallery
86 toy
hey let me know what you find out my 86 did the same thing it sucks!! good luck
slacker1 is offline
Old 06-07-2004, 10:07 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
are you sure it's firing? make sure, sounds like an igniter
雄のハヤブサ
Tercel GTS is offline
Old 06-10-2004, 12:29 AM   #5 (permalink)
yea its firering maby the distributer??
slacker1 is offline
Old 06-10-2004, 06:27 AM   #6 (permalink)
N/A bites
Tercel GTS's Avatar
fuel spark and compression are all that are needed to run, said you know yer gettin fuel and gas, check compression....
雄のハヤブサ
Old 06-10-2004, 02:55 PM   #7 (permalink)
reb
View reb's Photo Gallery
If you have spark, your timing chain might have jumped. To check, pull the plugs, rotate the crank until the timing marks line up. Then see if the rotor is pointing at the no. 1 plug wire connection in the distributor cap. A more accurate way (with the plugs out and the timing mark aligned) is to connect a timing light between the no. 1 wire and ground. Then slowly rotate the distributor back and forth. The light should flash as the cap is moved past the rotor at the #1 position.
reb is offline
Old 06-10-2004, 04:55 PM   #8 (permalink)
hey guys thankx i have already done that, timing is cool got sprk fuel and compres is at 160 straight across. aka what else can i try??
slacker1 is offline
Old 06-12-2004, 02:36 PM   #9 (permalink)
Do you have a 22r or 22re?
You say you have spark and compression. Starting fluid is good stuff, and doesn't need much spark to light it. Is your distributor in proper location as well as your plug wires?
Rycam is offline
Old 06-12-2004, 11:36 PM   #10 (permalink)
its a 21r with 86 22r intake and carb
slacker1 is offline
