Engine swap ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2004, 01:14 PM   #1 (permalink)
View juanda's Photo Gallery
Question Engine swap ?
Hi,
I'm new to this site, I have a question about engine swap.
My friend have a 83 celica gt engine 22re automatic, can i swap this into my 87 toyota pickup with 22r carburated engine 5 speed manual, is this possible..
Thanks in advance.
juanda is offline
Old 06-15-2004, 01:16 PM   #2 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
yeah you could but keep you 5spd and you'll need the harness from the celica or if you want you can change the intake manifold over
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline
Old 06-15-2004, 01:26 PM   #3 (permalink)
2wickedtoyz,
Thanks for quick response. How hard it is to switch all efi wiring from carburated..
juanda is offline
Old 06-15-2004, 01:31 PM   #4 (permalink)
Mad Scientist
if you have a complete car it's not that hard but take your time and it should go smoothly but if you just wanted a bigger motor it would be better to just take the motor and use your old manifold and car...i've seen intake manifolds that can use 4bbl carbs on it or you can get abbl weber carb adapter
Camry Wagon Crew
Old 06-15-2004, 01:34 PM   #5 (permalink)
2wickedtoyz,
juanda is offline
Old 06-15-2004, 01:45 PM   #6 (permalink)
Mad Scientist
it's not hard just takes time. remove the engine harness from the carb motor then remove the harness from the efi motor and put it in the truck it just takes time that's all
Camry Wagon Crew
Old 06-15-2004, 05:20 PM   #7 (permalink)
reb
View reb's Photo Gallery
I believe efi engines require a different fuel pump, which is usually in the fuel tank. Maybe fuel filter and some line changes, too. You might check into that before you start. good luck. Sounds like a lot of fun (and good experience).
reb is offline
Old 06-16-2004, 09:16 AM   #8 (permalink)
This is going to a long slow process , maybe i just use the carb instead lot more easier.
juanda is offline
