22re issues. Tap and rough idle. Please help
I have a 93 pickup with a 22re. I had a tap coming from the top end so I had the valves adjusted. A couple of weeks later I had a new timing chain, gears, guides, timing cover, etc. installed and the timing was reajusted. The truck ran very smooth at idle. This was about a month ago. I just put on a new exhaust manifold to quiet an exhaust leak and now that the exhaust is quiet, I have another loud tap from the top end. Is it possible that now that I have the new timing chain,etc. And the ignition properly timed, that I will need another valve adjustment, or could it be something else making the noise.
I also just recently had a check engine light come on after all the work was done. I noticed that two wires going to the O2 sensore were broken off at the harness. Not wanting to spend $500 on the new engine harness I spliced the two broken wires. The check engine light went out but the truck has seemed to idle rough ever since. I was wondering if there is maybe a replacement repair pigtail available for this harness or am I stuck with a new engine harness. And, considering that the engine light went out, is this even the cause for the rough idle? Any insight would be greatly appreciated. Thanks.
