91 truck oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2004, 10:35 AM   #1 (permalink)
View bruce conway's Photo Gallery
91 truck oil leak
I have a 91 pickup 4wd V6 engine with a bad oil leak from the front seal area. I am guessing it is the seal and looking for advice on changing the seal. Can I get the seal out by prying with a screw driver?
Also thinking of drilling the seal and inserting a sheet metal screw to pull on or maybe I have to buy a slide hammar.
Can I install the seal using a appropriate size sccket and tapping wioth a hammar ( my usual method of seal installation)
Can the oil leak be from somewhere else (commonly)
Thanks in advance.
bruce conway is offline
Old 06-28-2004, 11:51 AM   #2 (permalink)
View brokentoy's Photo Gallery
either method should work man, it's gonna take paitence though, kind of a tough place to get to. check the crank for scoring, you may need to speedy sleeve it
4wd, it helps ya go, but it won't help ya stop
brokentoy is offline
