go with drop spindles. our trucks already have small turning radiuses to boot. what happens when you install aftermarket drop spindles is that your offset gets lower making your tires rub just a little bit w/stock wheels and some aftermarket depending on the wheel's offset. but i still think drop spindles are more smoother than just dropping your truck with the existing torsion bars. the key to a more comfortable ride is quality shocks such as bilsteins,sway bars,lower profile bump stops f&r,drop leaf springs and aftermarket torsion bars.check
www.4wheelparts.com and
www.shox.com
