85 Toy won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2004, 01:42 AM   #1 (permalink)
View JdSto's Photo Gallery
Unhappy 85 Toy won't start
My trusty truck wont start. I will turn over but won't fire. I call pull start it and drive it all day and when I shut it oof and then try start it it will. But after sitting a few hours it won't start again. Is this a coil igniter problem? And how would I test for that, so that I'm sure what parts to get. I should qualify this by saying I'm not a mechanic but must fix this myself by nessesity. Any help would be greatly appreciated.
JdSto is offline
Old 08-24-2004, 02:25 PM   #2 (permalink)
View dondi_m's Photo Gallery
Don't really know without more info... Does it turn over? Does it start right away when you pull start it? Might be a fuel pressure problem...is it fuel injected?
dondi_m is offline
Old 08-24-2004, 08:16 PM   #3 (permalink)
Well when I turn the key it engages the starter and the engine turns trying to startbut won't fire and run.. I unscrewed a spark plug connected it back to the wire and had someone turn it over while I grounded the plug and no spark. Next I disconnected the wire that comes from the coil to the distributor and grounded it and had them try start it and no spark. To answer the other question, When I pull start it ,it fires immediately and runs like a champ. It does stall at idle sometimes right after I have first pull started it. And this is a carberated engine.
JdSto is offline
Old 08-25-2004, 09:07 AM   #4 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
your igniter might be going bad or already went
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline
Old 08-25-2004, 01:18 PM   #5 (permalink)
Sleeping While Awake
View 94 Yota's Photo Gallery
check your igniter, alternater, starter, plugs, wires.....
94- 22RE, 5spd, 33x12.50, Engbldr 261 cam
To Come:
5.29's, rear E-Locker, front tru-trac, 35's, Bobbed Bed,
blah blah blah
94 Yota is offline
