1987 22r Surging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-27-2004, 12:57 PM   #1 (permalink)
View coronet's Photo Gallery
Talking 1987 22r Surging
Hi all, I gotta wierd surge problem and I thought id throw it out there in case anyone can confirm or deny my suspicions...
Sometimes while driving, if I take my foot off the gas the engine is still running as if my foot is down...it will just run and run until I either pump the gas once or twice and it will go away, or if I push the clutch in I can hear the engine surge...and then go down to idle...as if something is getting "stuck" and either applying the clutch or feathering the gas will free it up.
Suspicion number 1 is the carberatur, maybe the lfoat ball is getting sucked up and stuck...suspicion number 2 is the accelerator cable getting siezed up in its cable housing, although that wouldnt account for the surge going away if I apply the clutch....
Any ideas? Id like to avoid having my mechanic do some troubleshooting at 100 bucks an hour...
"Gettin' it wrong since 72"
87 4X4 Toyota, Red Beater
coronet is offline
Old 08-27-2004, 05:06 PM   #2 (permalink)
Trailer Trash Engineer
alltrac165's Avatar
View alltrac165's Photo Gallery
Don't know about yours, but my 87 is fuel injected
Ya got me on that one. Maybe a vacuum leak? Although that doesn't explain the clutch thing either....
BTW, I think the absolute best truck shop in town is Marty's Import Truck Service.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen ) SOLD
alltrac165 is offline
Old 08-27-2004, 05:33 PM   #3 (permalink)
I hear ya on that one...I called all over town trying to find someone to help me with this idle problem I was having...after talking to at least 13 or 14 garages I found Import Truck Service to be the most help, Marty knows his business. Alot of these "mechanics" I talked to said things like "carberatuer huh? Thats a little before my time..." and then they would be like "try joe at so-and-so garage..." LOL.... Marty will get all of my truck business from here on out.
Im still poor though...so I try to fix whats i cans...
coronet is offline
Old 08-27-2004, 07:37 PM   #4 (permalink)
View Rycam's Photo Gallery
It seems unlikely that the carbs float valve would be sticking. You would have unburned fuel and sooty smoke out the tailpipe as well as more serious starting (flooded) and driveability problems.
The throttle cable may be sticking/there might be crud build-up on the firewall side of the carb where all the linkages are. Lube the throttle cable and pedal pivot for the accelerator pedal with silicone spray. Keep the spray off the pedals...and while your already in there, spray some silicone on the heater/ac box linkages, pivots and cables. Take carb cleaner and spray the carb.
This past winter a friend with a Ford Ranger had this happen. The colder it was, the worse the problem. A shot of carb cleaner fixed it.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 08-27-2004, 08:53 PM   #5 (permalink)
View andermac's Photo Gallery
Sometimes crud also builds up on the wall inside the throat of the carb. I usually take a piece of old t-shirt or something and use a screw driver to hold the butterfly valve open and wipe spray out of carb throat. I also had one onetime have ridges worn under carb butterfly and had to remove carb and apply sand paper to rough spots. Hope this helps!
"Can't never could do anything!"
Andy
andermac is offline
Old 08-28-2004, 11:07 AM   #6 (permalink)
alltrac165's Avatar
Does it have a high idle solenoid? Usually used to eliminate spitting under deceleration by keeping the throttle open just a bit. Sometimes it also keeps the idle speed up under other conditions if it's not working right.
Bob Raby
Santa Cruz, CA
Old 08-28-2004, 12:30 PM   #7 (permalink)
Thanks for the tips yall....
Im hoping its something as simple as the cable getting stuck, I dont wanna fool around with that carb anymore....
Ill see if some lube will do the trick....
cheers all!!
coronet is offline
