1987 4-speed trouble - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-02-2004, 07:53 PM   #1 (permalink)
View MrMike's Photo Gallery
Looking for some ideas. My 87 Extra Cab 4x4 just started popping out of 3rd gear (hard). I removed the shifter to make sure the bushing was ok and it appears normal. I've got about 165,000 miles on it and have replaced the fluid with 2 parts lube and 1 part Marvel Mystery. Counting on an adjustment and not a replacement.
Thanks for any input.
Thanks Much,
Mr Mike
MrMike is offline
Old 09-03-2004, 02:18 PM   #2 (permalink)
View obex26's Photo Gallery
Very common problem. No lube is going to stop it from coming out of 3rd gear. Sounds like the syncros are on their last leg. I suggest looking for a used replacement even a 5 speed at that. The cost for a used tranny will be alot less then trying to rebuild your 4 speed. You could easily swap it out yourself in a weekend. Another suggestion if you dont want to buy the toyota repair manual from the autoparts store you can go to your public library and usually find it there.
obex26 is offline
