stuck gas pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2004, 01:01 AM   #1 (permalink)
Sleeping While Awake
View 94 Yota's Photo Gallery
stuck gas pedal
posted this on another site, just curious to know what your ideas were. my gas pedal seems to get stuck after sitting for a while, and at times i almost have to kick it to get it moving, then its good to go after that, till i park it for a period of time again. any thoughts or suggestions?
94- 22RE, 5spd, 33x12.50, Engbldr 261 cam
To Come:
5.29's, rear E-Locker, front tru-trac, 35's, Bobbed Bed,
blah blah blah
94 Yota is offline
Old 09-09-2004, 08:03 AM   #2 (permalink)
TN's SRT-4
MenaceSQL's Avatar
View MenaceSQL's Photo Gallery
Check out this link to the other site.
My truck had the problem a couple of months ago. When I opened the hood and inspected, I noticed that one of my cables was having the problem that midiwall explained in that link. One of the cables hooking around my throttle cable wasn't going into its jacket. I tried my best to spray some WD-40 down that cable into the sleeve. Don't know if that did it but the problem disappeared shortly after and hasn't came back yet.
Temporary way of going around the problem:
Unstick the pedal first before starting the engine.
1989 Toyota 4WD P-up Ext. Cab SR5 V6 Auto (currently out of commission)
2005 Dodge Neon SRT-4
- 11.9 @ 117 1.79 60' (best trap 120 mph)
- 30.8 mpg city/hwy (pulse & glide), 33.4 mpg hwy
- 178,000+ miles (still on original motor)
MenaceSQL is offline
Old 09-09-2004, 02:24 PM   #3 (permalink)
thats the other forum i'm on and posted there. i just wanted to get some ideas from two sources and see what both say about it. im gonna try the wd-40 idea.
To Come:
blah blah blah
94 Yota is offline
Old 09-10-2004, 10:57 AM   #4 (permalink)
View mooseketer's Photo Gallery
My '93 does this too. The intake chamber needs cleaning. The flapper inside sticks. I put lots of miles on my truck so I have to clean it once or twice a year. Just remove the air intake hose and use carb cleaner and an old tooth brush to clean it.
mooseketer is offline
Old 09-10-2004, 01:09 PM   #5 (permalink)
View coronet's Photo Gallery
Hey all,
I have this problem as well, but I have a 22r Carbed.....no EFI
Is it the same procedure basically?
"Gettin' it wrong since 72"
87 4X4 Toyota, Red Beater
coronet is offline
Old 09-10-2004, 01:13 PM   #6 (permalink)
That's what I would guess... Sticky throttle.
Puddle Jumper
Old 09-14-2004, 08:40 PM   #7 (permalink)
View yoder-bug's Photo Gallery
another thing you can try instead of wd 40 (nnly because it has very little lub in it) is use some white grease in an arisol can...
ldm
yoder-bug is offline
Old 09-18-2004, 03:48 PM   #8 (permalink)
TN's SRT-4
MenaceSQL's Avatar
After looking over my truck earlier, I noticed that the cable I mentioned in my post above had a little section that had been scorched by my headers. This should be the reason why that cable had been acting up. The insulation that had been touching my headers is all gone.
