UPDATE: She just threw a code.. |||| | Throttle Positioning Sensor Signal. Would this have anything to do with the below problem? I can't see how a tps would cause that
Ok guys I posted a thread a while back entitled “cranks then dies like clockwork”. Well I have a new problem but before I begin on this whacked out problem I would like to thank all of you for you input on the last thread. I couldn’t have made it this far without it.
I now have a variant of my old problem. If you can get this you are the man.
I turn the key to the position right before the “cranking position” and the engine turns over and cranks. That means the engine is cranking in the normal run position and not the cranking position. And the starter never disengages.
Somehow it is also bypassing the clutch depression sensor. So I don’t even have to push in the clutch for it to crank. This would be expected considering the sensor only activates when the key is in the “crank” position and is deactivated in the “Run” position. However I believe this is a symptom of my problem and not the cause of it.
TROUBLESHOOTING
When I remove the EFI Relay located under the hood in the fuse box. The truck cranks as it is supposed to. Granted it will not run. But at least the engine turns over in the correct key position. Also the clutch depression sensor is once again activated. IE the truck cranks and acts as it is supposed to, but only when the EFI Relay is removed. AHH HA! I got it, BAD Relay you say……. Wrong.. $47 dollars and a Brand spanking new EFI Relay later she does the same thing. F’s up with the relay in, and does fine with it out.
If one of you guys can get this, you’re a better toymotor mechanic than I.
Thanks for all your help guys.
Guys to be honest with you, I am about ||| this close ||| to my next thread being.. Anybody know how to bracket in a carbed 350 SB into a 92 toyota.
