Towing w/ 4X2 Tocoma - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2004, 10:13 PM   #1 (permalink)
View Dan F's Photo Gallery
I have a new 2004 Tocoma and want to tow a boat with it. It does not have a towing package. What is the best connection for a 4 pin connector?
Dan F is offline
Old 09-22-2004, 01:46 AM   #2 (permalink)
Sleeping While Awake
View 94 Yota's Photo Gallery
best connection? like where would you attach a tow hitch too?
94- 22RE, 5spd, 33x12.50, Engbldr 261 cam
To Come:
5.29's, rear E-Locker, front tru-trac, 35's, Bobbed Bed,
blah blah blah
94 Yota is offline
Old 09-22-2004, 06:52 AM   #3 (permalink)
I can put a hitch on the bumper, but needed some advice on the best connector/converter to use for a 4 pin that matches my boat trailer.
Dan F is offline
Old 09-23-2004, 11:38 AM   #4 (permalink)
View obex26's Photo Gallery
I would not recommend towing with your bumper. Go get a reciever hitch from UHaul worth the 150 dollars and they give you a lifetime warranty (as long as you own the truck) They will even do the wiring for your trailer for another 20. Think of it like this. Its a new truck do it right and less chance of damage to your vehicle in the long run.
obex26 is offline
Old 09-23-2004, 03:20 PM   #5 (permalink)
reb
View reb's Photo Gallery
I used the bumper hitch on my T100 with fairly heavy loads on rough roads and eventually broke some welds holding the bumper on. If you avoid heavy loads and stay on good roads, the bumper hitch will probably serve you ok. As for wiring, you can find an aftermarket adapter for around $35 that will plug into your wiring harness. The cheapest source I found was JCWhitney. That is also a good source for a rugged, inexpensive receiver hitch.
reb is offline
Old 09-23-2004, 08:51 PM   #6 (permalink)
View MiniTruckDX's Photo Gallery
reese
advance auto parts can get them cheeper than U-Maul; then wire it with one of these
Ten minute install it is so easy. Reese is cheaper and better than Valley
I just installed this stuff on my wifes '04 Rav
It was Hella easy
MiniTruckDX is offline
