Howdy,
Can you or have you checked the OBD with a scan reader? This may point to a faulty sensor. Do you get a Check engine light?
Before that I'd check, air filter, vacuum lines, and maybe the fuel filter, sounds as though it running fine when cool because the mixture is enriched when the temp is low, but after it reaches operation temp, the mixture is leaner and thus it stalls unless you open the throtle which sends a signal for more fuel in the mix?
They are complex and self adapting systems, fuel/air/temp/ but from what you'd said, something in the trio is out of balance when the engine warms up. Any performance problems at high speed? Lack of power?
Free advise is worth what you paid for it so please consider this my opinion and not a repair suggestion.
I have the same truck, 97 version and like it alot. How long have you owned yours? Any transmission mysteries? Front end shimmy problems? Sure would appreciated hearing one way or the other.
Good luck
