advance adapters has everything u need. i checked them out when i wanted to fdo my swap and depending if you are going ot use stock tranny or not its around 3000. but thats with the 5 speed standard stock tranny. inclused every thing from bell housing to radiator hoses. . if you plan on going with say a 30 or 400 or 700r4 then it will be cheaper in parts but longer in time and possable even more wxpensive in the long run but check out
www.advanceadapters.com and they can hook you up with everything.
