Clunk When shifting into 4th & 5th - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2004, 08:49 PM   #1 (permalink)
1996 T100 Extra Cab 4x4
View captainehh's Photo Gallery
Unhappy Clunk When shifting into 4th & 5th
Hey guys-
I own a 95 Tacoma 4x4 that runs awesome minus this problem. I run the 5 speed manual. The clunk happens when i upshift from 3rd to 4th and 4th to 5th. It's most apparent when i release the clutch at a normal pace. It's still there, but less noticable even when i let the clutch out real slowly. It's not there when downshifting or upshifting into 1,2, or 3. It's a clunk you feel in the seat of your pants. It's definitely coming from directly below me. Loose driveshaft bolts? U-joints bad? What's going on here??
captainehh is offline
Old 10-27-2004, 11:05 PM   #2 (permalink)
reb
View reb's Photo Gallery
I'm not sure what it is, but I would crawl underneath and check the u-joints. Maybe jack up one side of the rear and rotate the driveshaft back and forth to see if anything strange is going on. There should be no noticeable play in the u-joints.
reb is offline
Old 10-28-2004, 11:30 AM   #3 (permalink)
Whats the best way to check for play in the U-Joints?
Old 10-28-2004, 02:57 PM   #4 (permalink)
reb
With the transmission in neutral and one wheel jacked up, rotate the driveshaft back and forth. The other end of the u-joint should respond immediately, as if it were one solid piece--no detectable relative movement.
reb is offline
Old 10-28-2004, 08:26 PM   #5 (permalink)
Excellent. Thank you. I'll have to get my hands on a floor jack.
