Code P0171 Left bank too lean - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2004, 05:37 PM   #1 (permalink)
View hpyman123's Photo Gallery
Getting this code when I scan computer on my 97 Land Cruiser. Have replace front O2 sensor per dealer recommendation but am still getting the code. Anyone familiar with this??
hpyman123 is offline
Old 10-28-2004, 05:43 PM   #2 (permalink)
View deekay140's Photo Gallery
Po171 is system too lean, the most common cause would be a bad mass air flow sensor.
have seen a few coolant temp sensors bad also.
deekay140 is offline
Old 11-01-2004, 11:13 AM   #3 (permalink)
Code issue
Thanks for the response. Anything else that could be the problem?
Old 11-03-2004, 01:52 AM   #4 (permalink)
View OEMonkey's Photo Gallery
deekay is right. if manifold vac and fuel pressure checks out ok, it's almost always the maf sensor.
OEMonkey is offline
Old 11-03-2004, 12:24 PM   #5 (permalink)
Po171
Thanks for the help I appreciate it.
Old 01-17-2005, 05:10 PM   #6 (permalink)
View raycwang's Photo Gallery
Check my post on this forum on "P0171", I cure it by clean the MAF sensor, after spending money for new fuel filter, cleaning injector and new O2 sensor. It seems the dealer alway start with the most expansive part to replace instead of the cheapest cure.
raycwang is offline
Old 01-17-2005, 07:52 PM   #7 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000464
View humanoid's Photo Gallery
I'm betting 99.99% that it's the MAF sensor. Give it a good cleaning and reset the ECU and you will be !
This is my sig.
humanoid is offline
Old 01-17-2005, 08:03 PM   #8 (permalink)
View Smoke's Photo Gallery
Are you using the K&N air filter?
94 Toyota PK Ex-Cab 3.0 4X4 Auto
Smoke is offline
