I have a Toyota radio that came out of my T-100 that I want to install in my 83 toyota longbed.
When it was removed from the T100 they just removed the plug-in's that connected it to the truck, cut off the plug in's and threw them away.
I have looked at the following site:
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
but the images do not match the back of my radio cassette player. I have attached an image of the rear.
As you can see there are 2 connectors as seen in the above mentioned web site. However there are more pins than there are indicated on the site.
On the large one there are 5 across the top and 7 on the bottom.
The second one has 7 on the top and 8 along the bottom.
What I am asking for is what do each of the pins do so I can wire it up in my son's truck.
Thanks in advance,
peter
