1990 toyota 4 cylinder pickup carburetor replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2004, 01:14 PM   #1 (permalink)
View tlb1984's Photo Gallery
Unhappy 1990 toyota 4 cylinder pickup carburetor replacement
I own a 1990 4 cylinder 2wd with a 22R engine. It has just over 141,000 miles. For the past several weeks the fuel milage has gone down. A tuneup and fuel flush was done, but with little affect. the mechanic suggests a carburetor replacement is needed. The symptoms I see are: backfiring on shifting from 3rd to 2nd and/or releasing the gas peddle for braking. There is also a rich gas smell around the exhaust. The last thing i noticed is that during idle it sounds like it wants to die. I am wondering if i can order a replacement kit from napa or if I should just order a rebuilt one. I need the truck to last a couple of more years for my teenage son. One other question is the adjustment screws that can make the mixture richer/leaner. how can I make the adjustments by "sound" of engine at idle
tlb1984 is offline
Old 10-30-2004, 04:31 PM   #2 (permalink)
View 924runner's Photo Gallery
i didnt think they had carbs in 90
1992 4 runner 22r-e,cam,lift,35 inch tires,arb rear
http://bc4x4.com/album/steve-micaelo.jpg
924runner is offline
Old 11-04-2004, 01:02 PM   #3 (permalink)
View SpeshalK_82's Photo Gallery
Go with a Weber
If you are going to replace the carb. Check your local parts store and/or ebay for a 32/36 mm carb. you'll get increased power and fuel economy. You'll aslo need an adapter from carb to manifold, but you can get that at your local auto parts store. I recently put one of these webers on my 1982 Toyota 2wd with the 22R. It made a world of differnece.
SpeshalK_82 is offline
Old 11-06-2004, 07:31 PM   #4 (permalink)
1990 toyota carb repl
thanks for the info and help!!!!!!
tlb1984 is offline
Old 11-17-2004, 05:01 PM   #5 (permalink)
View aerwin's Photo Gallery
I must be having the same problem. my calif. emissions test came back as running real rich. my toyota is an 86' carburated but I also have to keep stock for smog reasons, I am assuming a rebuild should help, 190,000 on original carb, runs real good but fuel is going through a diaphram I think, is the weber calif legal
aerwin is offline
Old 11-18-2004, 10:16 PM   #6 (permalink)
Banned
subliminaltrips's Avatar
View subliminaltrips's Photo Gallery
i agree a weber is a great carb i had on a mazda b2200 and it made a huge differance in fuel and power i didnt know they were carbed in 90 either...??
subliminaltrips is offline
Old 11-19-2004, 12:22 AM   #7 (permalink)
toy283's Avatar
View toy283's Photo Gallery
'87 was the last year for carbs on 4WD models, '90 was the last year on 2WD models.
Dave
'84 XCab, blown 283 V8, SM420, dual cases, etc.
'85 4Runner
home.comcast.net/~toy283
toy283 is offline
Old 11-19-2004, 03:23 AM   #8 (permalink)
Pre Taco= Built Better
View toyota_s_runner's Photo Gallery
I have right now a 90 and a 91. The 90 "was" carbed and the 91 is FI. I now have on my 90 a Holley 650 CFM DBL pumper. and it runs great
www.tacomasrunner.com .......
toyota_s_runner is offline
Old 11-22-2004, 10:11 AM   #9 (permalink)
View delta yankee's Photo Gallery
cost?
How much did your replacement carb cost? Delta Yankee
delta yankee is offline
Old 11-28-2004, 08:54 PM   #10 (permalink)
I actually did some shopping on ebay and ended up with a good used 32/36 for $130. I then had to purchase the carb to manifold adapter and i put a rebuild kit in it just to be safe. I also had to get the throttle linkage adapter.
