question regarding locking rear differential
I have a 2004 tacoma double cab with the rear locking diff. When I put the truck into 4lo and then select the locking diff the light just blinks, but if I turn off the locking diff and spin the tires,then try the diff again it seems to lock after that. Is this normally how it works or should I take back to the dealer? It seems you should be able to enable it before you get stuck, although the books says only to use after you have gotten stuck and tried 4hi and 4lo. Any help would be appreciated. Thank you.
