Is it my carb or ignition problem
Gots a 89 toyota truck with a 32/36 carb, its only now that the truck is idling funny... Heres the problem when The truck is cold it runs fine, as soon as it reaches engine temperature and I drive it around the block couple of times the idle immediately drops to 300-100 RPM & seems like it wants to die out on me but can't, when I try gassing it, it starts bogging and the RPM acts all crazy like it doesn't want to rev, as I try reving it the truck starts to backfire a little.... You can see on my previous post that I tried everything from spark plugs, to cap & rotor, ignition timing, changing spark plug wires and probing the ignition components and still can't solve this problem... could this be cause by a vacuum leak or a faulty coil..... let me know if u got this kinda problem before... Thanks
